What you're looking for is in the 'solution' box in the constraint dialog.
For a mate, the flipped condition is actually a slightly different
constraint (flush). You can toggle between the two at will. The angle
constraint has a flip option for both faces that is more like the MDT
method. It's just a slightly different workflow to achieve the same result.
It's easier IMO, but takes a bit of getting used to.
Walt
"Timothy O'Connell" wrote in message
news:3F4CEF33.2F1E272B@cornell.edu...
> When constraining 2 parts together, how do you change the direction
> of the arrow defining the constraint plane? This was a simple "flip"
> in a dialog box MDT.
> Thanks,
> Tim
