When I open the Bill of materials in the assembly file it looks like the attached Assy. BOM.
Inserting the same BOM into the drawing it changes. My supervisor wants me to only edit the
assembly BOM. No edits to be done on the BOM in the drawing. As an example, I have to change
Item 291 to 018. Item 018 is the correct part in the assembly file. Item 291 is not anywhere
in our system vault or otherwise. Nor are the other 290 series numbers listed on the drawing
BOM. Has anyone had a similar issue.
gaitano
Solved by gaitano99. Go to Solution.
Nelson_C
I appreciate your response. It was very helful and I did solve my problem.
Issue Resolved.
Thanks Much!
Gaitano99
