Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
Did you mean:Ā
Assembly BOM Different When inserted into drawing
2 REPLIES 2
gaitano99
841 Views, 2 Replies
When I open the Bill of materials in the assembly file it looks like the attached Assy. BOM.
Inserting the same BOM into the drawing it changes. My supervisor wants me to only edit the
assembly BOM. No edits to be done on the BOM in the drawing. As an example, I have to change
Item 291 to 018. Item 018 is the correct part in the assembly file. Item 291 is not anywhere
in our system vault or otherwise. Nor are the other 290 series numbers listed on the drawing
BOM. Has anyone had a similar issue.
gaitano
2 REPLIES 2
Nelson_C
in reply to: gaitano99
Don't you just need to sort by stock number and re-number the series? Here's a nice rundown on BOMs I just found: http://aucache.autodesk.com/au2012/sessionsFiles/4683/451/VirtualHandout_4683_MA4683-V%20-%20BOMs%20...
gaitano99
Nelson_C
     I appreciate your response. It was very helful and I did solve my problem.
Issue Resolved.
Thanks Much!
Gaitano99Smiley Happy
