I use assemblies in libraries sometimes, when I'm working a side project and
need to reference the assembly without accidentally making changes to the
assembly.
The thing to remember is that if it's in a library, IV will treat it as
read-only. If you need parts to change position or whatnot, you cannot use
a library path.
What problems are you having with check-out/in? About the only problem we
have is people forgetting to check stuff back in...
-Brian
"Corey Parks" wrote in message
news:667AAF20D2C5EE0141DB4143FE017CE9@in.WebX.maYIadrTaRb...
> Anyone ever put assemblies, like cylinders, ball screws and slides, in
> library paths? If you move the cylinder from extended to retracted and
save
> it is extended again when you reopen, is it not? Is this not a bit of a
> problem? Do you all just create the path for you cylinders as a workgroup
> instead of as a library? What work arounds do you all use? I am trying
to
> implement IV6 and this is one of our issues as well as the new check in
and
> check out nightmare, but that is for another time.
> Corey Parks
> Mechanical Designer
> Metro Machine & Engineering Corp.
> www.metromachine.com
> cparks@metromachine.com
> (952)-259-3684
