Inventor General Discussion
Member
Fefas
Message 1 of 5 (159 Views)
Assemble Multiple leds on matrix
159 Views, 4 Replies
09-26-2012 06:02 AM
Guys,
I am assembling multiples leds on a matrix that I made.
Is there any way to make the assembly using constrains to place the ipt LED design on the matrix without placing one by one?
The constrain I am using for each led is Insert.
There got to be a way to insert the leds directly, like when you are placing screws and it detects all holes and places the necessary number os screws on the existing holes.
Any Idea will be aprecciated.
Fefas
Fefas,
Have you looked into patterning?
Cadmanto
Message 2 of 5 (154 Views)
Re: Assemble Multiple leds on matrix
09-26-2012 06:13 AM in reply to: Fefas
Fefas,
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
JDMather
Message 3 of 5 (141 Views)
09-26-2012 07:32 AM in reply to: Fefas
If you created the holes in the original part with a Feature Pattern you can use that same part Feature Pattern to place the LEDs in the assembly.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Member
Fefas
Message 4 of 5 (139 Views)
09-26-2012 08:08 AM in reply to: Cadmanto
Thanks Scott,
It worked. I don't know how I haven't noticed that on the assembly I could use the patter tool.
Cadmanto
Message 5 of 5 (132 Views)
09-26-2012 08:12 AM in reply to: Fefas
We all over look things at time.  Glad it was that easy.
Best Regards,
Scott McFadden
