Inventor Forum
Assemble Multiple leds on matrix
4 REPLIES 4
306 Views, 4 Replies
Guys,
I am assembling multiples leds on a matrix that I made.
Is there any way to make the assembly using constrains to place the ipt LED design on the matrix without placing one by one?
The constrain I am using for each led is Insert.
There got to be a way to insert the leds directly, like when you are placing screws and it detects all holes and places the necessary number os screws on the existing holes.
Any Idea will be aprecciated.
Fefas
4 REPLIES 4
Cadmanto
Fefas,
Have you looked into patterning?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
JDMather
If you created the holes in the original part with a Feature Pattern you can use that same part Feature Pattern to place the LEDs in the assembly.
in reply to: Cadmanto
Thanks Scott,
It worked. I don't know how I haven't noticed that on the assembly I could use the patter tool.
Cadmanto
We all over look things at time.  Glad it was that easy.
Best Regards,
Scott McFadden
