Inventor Forum
Artwork - Silkscreen
16 REPLIES 16
Message 1 of 17
535 Views, 16 Replies
Here's my situation:
I have a formed sheet metal part that has to be
powder coated and then have stripes silk-screened on it.
I have tried to "cut" .0001" deep stripes on the part, (so that I could
assign a different color)
but after doing so, it doesn't unfold the part.
(I posted a jpg in CF under "stripes")
Anyone else have any experience with this type of situation?
Would this be a good application for the decal thing?
-Ken
16 REPLIES 16
Message 2 of 17
I would definitely use the decal. In reality you aren't cutting anything
into the material so why do so in the model? I can't comment on why it
won't unfold as I haven't looked at the CF post.
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
"Ken Schumacher" wrote in message
news:CACCD43BA23D07AB94E6BA07EAD1F051@in.WebX.maYIadrTaRb...
> Thanks,
> -Ken
Message 3 of 17
Sean,
The post in CF just shows what I'm trying to accomplish.
I'll have to look into that decal thing.
"Sean Dotson" wrote in message
news:6258CD1AFC4136DC58CA12398254CADF@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> > Thanks,
> > -Ken
Message 4 of 17
Sean,
Do you know off hand if the decal can be projected,
or will it automatically wrap around the forms?
> Sean Dotson, PE
> > Thanks,
> > -Ken
Message 5 of 17
Yes you can make it wrap to all three of the faces (the two flat ones and
the angled one)
Sean Dotson, PE
news:4E37F60D58082E3BB88842D5E7ACFBB7@in.WebX.maYIadrTaRb...
> Sean,
anything
> > Sean Dotson, PE
could
> > > Thanks,
> > > -Ken
Message 6 of 17
That's cool, but can I just project it?
I'm envisioning that I will create a separate "part"
for the decal, and then apply that in an assembly.
If it were to wrap, I would have to figure out some kind of allowance for
the bending of the decal,...no?
news:8C6322C97655D4A7D3E2D27054760A3E@in.WebX.maYIadrTaRb...
> the angled one)
> Sean Dotson, PE
> > Sean,
> anything
it
> > > Sean Dotson, PE
> could
> > > > Thanks,
> > > > -Ken
Message 7 of 17
That's not how decals work. You apply them to individual parts, not to the
whole assembly. See Cf for an example..
Sean Dotson, PE
news:C860E96DD2253BDB65A1423F8948699E@in.WebX.maYIadrTaRb...
and
> > the angled one)
> > Sean Dotson, PE
> > > Sean,
> > anything
> it
> > > > Sean Dotson, PE
> > could
> > > > > Thanks,
> > > > > -Ken
Message 8 of 17
If I have this correct, you can't create (or design) the decal itself in
Inventor?
You have to use a bitmap, Word document or Excel spreadsheet?
news:08D61231810A84F4549C8CFA9B45F632@in.WebX.maYIadrTaRb...
the
> Sean Dotson, PE
for
> and
> > > the angled one)
> > > Sean Dotson, PE
> > > > Sean,
> > > anything
why
> > it
> > > > > Sean Dotson, PE
message
I
> > > could
> > > > > > Thanks,
> > > > > > -Ken
Message 9 of 17
That is correct AFAIK
Sean Dotson, PE
news:431D8E330CC4843EA6EC007F7FD30623@in.WebX.maYIadrTaRb...
> Inventor?
> the
> > Sean Dotson, PE
> for
ones
> > and
> > > > the angled one)
> > > > Sean Dotson, PE
> > > > > Sean,
> > > > anything
> why
> > > it
> > > > > > Sean Dotson, PE
> message
that
> I
> > > > could
> > > > > > > Thanks,
> > > > > > > -Ken
Message 10 of 17
I suppose he could model it in IV and make a bitmap of the image.
Seems like a bas ackwards way to do it but...
Richard
Message 11 of 17
That's an interesting idea...
Sean Dotson, PE
"Richard Hinterhoeller" wrote in message
news:3DD28283.1080703@hfx.eastlink.ca...
> Richard
Message 12 of 17
Just finished trying that. Doesn't really fulfill my needs.
For what I'm trying to do here, this decal tool is useless.
I need to dimension the stripes so that they are in a specific location.
It would be different if all I needed was a pretty picture.
news:0E304D0B6C99464433FC5DBAE78995F4@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> > Richard
Message 13 of 17
Ken
Can';t say I have tried it, but if it is just lines, how about drawing it up in AutoCAD,
and then doing a Bmpout, and using it. I would think it should be able to end up with the
lines in the right places then. In the IDW you could probably add small sketch lines
where needed and dimension to them?
Kent
Member of the Autodesk Discussion Forum Moderator Program
news:992CBA8C0D2223B6B6333CCA11BC9183@in.WebX.maYIadrTaRb...
Message 14 of 17
Hey Kent,
I just had a brain storm that I'm going to try.
I'll let you all know if and how it works.
Thanks for all the suggestions!
-Ken
"Kent Keller" wrote in message
news:EBDCC1A4D1955B56939FAF37F5C86B8F@in.WebX.maYIadrTaRb...
> Ken
up in AutoCAD,
end up with the
sketch lines
> Kent
Message 15 of 17
Maybe the same one you just came up with, but.... you can also just show sketch lines in
IDW's now, so you could just sketch the lines on the part. (note I haven't looked at
your part to see how feasible it is)
Kent
news:D6724BCD8F900BEF0B1F3983D6123E11@in.WebX.maYIadrTaRb...
> Hey Kent,
> -Ken
Message 16 of 17
No,
I decided to try keeping the stripe to the inside
edge by .00001" and continue to use the "cut" method. (.0001" deep.)
This seems to work satisfactorily for me.
It allows me to unfold the part and I can dimension the stripes.
(The stripes don't even show up on the flat blank!)
Thanks again for all the suggestions.
-Ken
news:383E5CFCEA3ED6AA08E36897F482FBDA@in.WebX.maYIadrTaRb...
sketch lines in
haven't looked at
> Kent
> > Hey Kent,
> > -Ken
Message 17 of 17
rllthomas
You still need to get an artmaster made for the silk screener. Typically what they do is print out your lines along with crop marks and take a photo of it and transfer that onto a clear film. We typically export our geometry into Autocad and then create the silk screen there. If it has raster images too we pump it into CorelDraw. We then send only the silk screening, a titleblock, and the cropmarks to the silkscreen house that makes the artmaster from that. We also reimport the silk screening back into the Inventor Drawings which is very tedious. In R6 you could conceivable draw the silk screening on the part and show the part sketch in the drawing however part sketch text entities only show up as a bounding box and you wouldn't have any raster images.
