I am trying to drill a series of blind holes perpendicularto the surface of a sphere. I have projected a set of points via an Excel spreadsheet as well as a separate set of sketch circles, which cannot be achieved by a normal circular array.
I have tried the Engrave command using sketch circles to no avail as the error message states it cannot be applied to a spherical surface.
I can obviously create a workplane on any one of the points perpendicular to the surface and create a sketch to extrude but I cannot do that 1000 times!
I have seen online videos of text engraved to a spherical surface but I cannot get my sketch circles to work.
Can anyone help me please with a solution.
Many thanks,
CJJ
CJJ
Why not?
In any case, I do see some patterns that can reduce the number of times you would have to do this, but there is no Easy Button solution.
This is not perfect (nor finished) but it might be close enough depending on your design intent.
It will take a while to rebuild when you move the eop to the end.
Hi Rdyson,
I am most grateful, thank you.
I have opened your file, moved the eop to the end and will come back to you when done.
Thank you once again.
CJJ
Hi again rdyson,
Your file has settled and I am indeed most grateful. As I have to be sub mm perfect in the positioning I will look at what you have done in more detail and see if I can replicate your arrays only more accurately.
I will come back to you in about 12 hours ...lol!
In the meantime thank you once again it's just the sort of response I was looking for.
CJJ
