ok, thanks
Jørgen
"Jeff Howard" wrote in message
news:44E58B825EF2645C2CF3341934206056@in.WebX.maYIadrTaRb...
> I think that's just the nature of patterned sketch entities. You can rmb
a
> patterned entity and edit the pattern.
> I've almost always had better luck with patterned features than patterned
> sketch components (see reply in CF). They crashed 5 a lot and apparently
are
> still prone to some problems as shown in CF "sketch pattern / constraints
> (IV6SP1)".
> I'm not sure why some ipt's show up embedded in the message window, but if
you
> will zip the file it doesn't happen (good practice anyway). Also, if you
will
> roll the EOP up before saving it makes the file a bit smaller.
> Jeff
> "JGH" wrote in message
> news:91E383A55B49542FC457654456901115@in.WebX.maYIadrTaRb...
> Sketchmode: I array som holes in a circular pattern and creates tangent
> lines between them, now I want to trim away parts of the patterned
circles,
> but I can`t. Neither can I extrude only the "desired" "shape" nor change
the
> array pattern ?
> I`ll try to post the file so you can see, I want this to result in some
sort
> of a knob/handle.
> Regards,
> Jørgen
