I am new to Inventor. At the moment I am trying to learn the basics by going through the Mastering Inventor 2013 book. I have previously sketched lines and tangent arcs so I know how it is supposed to work but on this new install of Inventor I am only able to draw line segments. When I try to drag an arc all I get is a line from the previous end point and the new end point. I think it is related to the fact that coincident restraints are not being made automatically as I draw but I have not been able to find where to turn that on.
Thanks in advance
Bruce
Solved by JDMather. Go to Solution.
Solved by trumpy81. Go to Solution.
Bruce, when in the sketch environment, click on the black triangle beside 'Constrain' along the bottom edge of the ribbon. You should be able to select 'Constraint Options' from there and change them as desired.
Using the line tool to create arcs can take some skill to master. Whenever I attempt to use it I usually end up with a reverse circle instead of an arc, which is not what I want most of the time. How I manage to do that is a mystery to me but it happens more often than not.
It can be a little bit dependant on what mouse you are using too. I find that with my current Logitech MX518 Gaming mouse that it is a lot harder to initiate an arc than it was with my previous mouse. YMMV.
Your conclusion that it may be non existent coincident constraints is most likely correct as that is something I have complained about, among other things, in 2013.
In short - check your Constraint Persistence and Constraint Options.
(You might attach screen shots of both here.)
