Inventor Forum
Arc Length
4 REPLIES 4
smg5101
15786 Views, 4 Replies
Arc Length
I want to dimension an arc by its arc length using Inventor 2009. When I select the arc and right click the only dimension options available are diameter and radius. How can I expand these options, or is there another way to dimension by arc length?
Tags (2)
4 REPLIES 4
JDMather
in reply to: smg5101
@smg5101 wrote:
... or is there another way to dimension by arc length?
Are you in ipt sketch or in idw or dwg?
You could update to later release.
In sketch - see attached.
Never mind - I can't fine my example file from back then.
It involved creating a parameter to control arc length in sketch, based on the formula for circumference of a circle.
smg5101
in reply to: JDMather
I am in the sketch mode of a .ipt file.
JDMather
Check this thread
http://forums.autodesk.com/t5/Autodesk-Inventor/Dimension-Arc-Length/m-p/3095050/highlight/true#M408...
Yijiang.Cai
Currently Inventor 2013 supports to create arc length dimension directly, please see the attached image "ArcLength".
For the old release, we could use the formula like Arc Length=PI*Radius*Angle/180, please see the attached image "Formula".
Hope it helpful for you!
River Cai
Inventor Quality Assurance Team
Email: River-Yijiang.Cai@autodesk.com
