Hi im CAD student nearly finished my HND.. ive been battling for days trying to get the arbor press tutorial on inventor 2014..
i downloaded the tutorial pack for 2014 but its not in there, im pretty sure its in the 2012 one so i tried to download that & unzip to the tutorial folder for 2014,, this doesnt work..
basically i want this tutorial to reverse engineer the rack and pinion system, im designing an fsae racing car i have almost everything done exempt my rack and pinion..
i know i could make one pretty qick but it wont function 100 percent, can anyone help with ethier getting this tutorial or something simmaler with a rack and pinion gear..
ps if anyone has any tips on how to use the gear tools on inventor 2014 for a rack and pinion system as far as i am aware it doesnt allow you 2
thanks alot i only have a few days to finish my project quick replys are appreciated
Solved by JDMather. Go to Solution.
Hi 0705640,
Have a look at this link, I think the arbor press is in the sample files:
I hope this helps.
Curtis
Here is the assembly (which I downloaded from the 2014 tutorial dataset).
The model is in the tutorial files download, NOT the samples files (and it is in the response just above).
