Inventor Forum
Apply different colors to different surfaces of same component
2 REPLIES 2
758 Views, 2 Replies
hi everybody!
i meet a problem when i try to render a set of press mould, using autodesk showcase, after it's modelled with inventor.
to make it easy to understand my problem, i would like to simplify in this way:
suppose i make a box with 6 surfaces, front & back, top & bottom, left & right. by default, if i set a certain color to this box, all these 6 surface will be the same.
but my intension is to make 1 color on 1 surface respetively, so the box will have 6 colors totally in the end.
does anybody know how to do this in autodesk inventor or showcase?
p.s. i knew how to do this before, but i already forgot, and i didn't find the answer after searching a for a whole morning.
thanks a lot in advance and best regards!
2 REPLIES 2
MingweiGao
In inventor, you can right click on one or several face(s) and select its properities. And then you can change the face appearance.
Steven Gao
Sr. SQA Engineer
in reply to: MingweiGao
thanks a lot! i also found another solution in showcase: http://www.cadalyst.com/design-visualization/three-autodesk-showcase-tips-13599?page_id=1
