hi everybody!
i meet a problem when i try to render a set of press mould, using autodesk showcase, after it's modelled with inventor.
to make it easy to understand my problem, i would like to simplify in this way:
suppose i make a box with 6 surfaces, front & back, top & bottom, left & right. by default, if i set a certain color to this box, all these 6 surface will be the same.
but my intension is to make 1 color on 1 surface respetively, so the box will have 6 colors totally in the end.
does anybody know how to do this in autodesk inventor or showcase?
p.s. i knew how to do this before, but i already forgot, and i didn't find the answer after searching a for a whole morning.
thanks a lot in advance and best regards!
In inventor, you can right click on one or several face(s) and select its properities. And then you can change the face appearance.
thanks a lot! i also found another solution in showcase: http://www.cadalyst.com/design-visualization/three-autodesk-showcase-tips-13599?page_id=1
