Inventor Forum
Apply Design View
4 REPLIES 4
SteveFrey
806 Views, 4 Replies
Apply Design View
When in a .IDW file you can right click the view and select APPLY DESIGN VIEW to have the view represent the current state of the assembly.  I always want to show the current assembly as drawn.  Is there a way to have this update by itself automatically?
Steve Frey
Inventor 2021
Windows 10 Professional 64-bit
HP ZBook 17 G6
Processor: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
Memory: 80 GB
NVIDIA Quadro RTX5000
3D Connexion SpaceMouse Wireless
4 REPLIES 4
blair
in reply to: SteveFrey
Make sure you don't use the Apply Design View or use the "Differ Updates".
Delta Tau Chi ΔΤΧ
SteveFrey
in reply to: blair
I'm not sure what you mean.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
blair
If you just place the view in your IDW without using the options that I posted, each time you either open the IDW or look at a different page, the view is checked and updated from the model.
Delta Tau Chi ΔΤΧ
johnsonshiue
Hi! Did you check "associative DV" checkbox in the drawing view? With the option check, the drawing view should be in sync with the model in the given DV. If it is not doing that, there could be a problem. Could you show me a dataset exhibiting the behavior?
Many thanks!
Software Test Engineer
