Inventor Forum
Apply a profile to the edge of solids
7 REPLIES 7
Message 1 of 8
hugoagogo
1544 Views, 7 Replies
Hi im fairly new to inventor and looking for a solution for something i hope is quite a simple task
I am currently in the process of designing a marble run for my Design and Technology Major Project and for some of the parts i am looking for a simple way to add a channel to the edges of some pieces (when i make these pieces they will be cut out of a sheet of wood and then a router used to add the channel profile)
I hope that i have made myself clear and someone here is able to help
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: hugoagogo
Can you attach the file here?
Without anything to look at (not even a screen shot) it sounds like a Sweep would create the feature you want.
The plastics feature Lip might also be a solution.
Message 3 of 8
hugoagogo
in reply to: JDMather
Sorry i didnt upload a part i have some messy dependancies that i am in the process of cleaning up. Here is a screenshot though of a typical part.
In the picture i have drawn a line along the edges that should have the chanel in them
Message 4 of 8
Dennis_Jeffrey
You could use a offset workplane on this part, going through the center. Then create a 3D sketch that utilizes the worrkplane and desired part faces.
See attached.
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Message 5 of 8
hugoagogo
in reply to: Dennis_Jeffrey
I am not quite sure what you are suggesting i do in the 3D sketch, i have had even less experience in this enviroment
Message 6 of 8
Dennis_Jeffrey
Once created, you can use the 3D Sketch as a sweep or loft path to create your feature.
Have you gone through all the tutorials included with Inventor?
See included file
Message 7 of 8
JDMather
I would simply do two 2D sketches.  No 3D sketches needed from what I can see.  One 2D sketch for your Sweep path and one 2D sketch for the profile (which I assume would simply be a circle for your marble channel).
What version of Inventor are you using?
Here is one that would require a 3D sketch for the Sweep path.
http://forums.autodesk.com/autodesk/attachments/autodesk/78/295240/1/Loop%20d%20Loop.gif
Message 8 of 8
hugoagogo
Took a bit of fiddleing to figure out how to get it to work but i finaly got there, sweep worked will with 2d sketches
