Hi im fairly new to inventor and looking for a solution for something i hope is quite a simple task
I am currently in the process of designing a marble run for my Design and Technology Major Project and for some of the parts i am looking for a simple way to add a channel to the edges of some pieces (when i make these pieces they will be cut out of a sheet of wood and then a router used to add the channel profile)
I hope that i have made myself clear and someone here is able to help
Solved by JDMather. Go to Solution.
Can you attach the file here?
Without anything to look at (not even a screen shot) it sounds like a Sweep would create the feature you want.
The plastics feature Lip might also be a solution.
Sorry i didnt upload a part i have some messy dependancies that i am in the process of cleaning up. Here is a screenshot though of a typical part.
In the picture i have drawn a line along the edges that should have the chanel in them
You could use a offset workplane on this part, going through the center. Then create a 3D sketch that utilizes the worrkplane and desired part faces.
See attached.
I am not quite sure what you are suggesting i do in the 3D sketch, i have had even less experience in this enviroment
Once created, you can use the 3D Sketch as a sweep or loft path to create your feature.
Have you gone through all the tutorials included with Inventor?
See included file
@hugoagogo wrote:I am not quite sure what you are suggesting i do in the 3D sketch, i have had even less experience in this enviroment
I would simply do two 2D sketches. No 3D sketches needed from what I can see. One 2D sketch for your Sweep path and one 2D sketch for the profile (which I assume would simply be a circle for your marble channel).
What version of Inventor are you using?
Here is one that would require a 3D sketch for the Sweep path.
http://forums.autodesk.com/autodesk/attachments/autodesk/78/295240/1/Loop%20d%20Loop.gif
Took a bit of fiddleing to figure out how to get it to work but i finaly got there, sweep worked will with 2d sketches
