Inventor General Discussion
Valued Contributor
richard_cirillo
Message 1 of 5 (122 Views)
appearance
122 Views, 4 Replies
04-09-2014 08:44 AM
added a mesh look to the part.
inside where the mesh is added the color is grey.Do i also add the texture to the inside.
What i should be asking is this appearance applied properly?
richard_cirillo wrote:
...are you saying make the part with 2 features and have each as a solid body?
Yes (in the same part file).
JDMather
Message 2 of 5 (118 Views)
Re: appearance
04-09-2014 08:52 AM in reply to: richard_cirillo
I suggest you go the other away around and make the part properties the expanded metal and then change the face properties of those faces you DON'T want as expanded metal.
Another option is multi-body solids.  (I suspect you will have to use multi-body on this.)
It also helps to place in assembly and have some other part behind this part so that you see the part behind.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
richard_cirillo
Message 3 of 5 (111 Views)
Re: appearance
04-09-2014 08:59 AM in reply to: JDMather
I will try that
Another option is multi-body solids.  (I suspect you will have to use multi-body on this.)...are you saying make the part with 2 features and have each as a solid body?
JDMather
Message 4 of 5 (107 Views)
Re: appearance
04-09-2014 09:01 AM in reply to: richard_cirillo
Valued Contributor
richard_cirillo
Message 5 of 5 (102 Views)
Re: appearance
04-09-2014 09:06 AM in reply to: JDMather
That certainly solved the appearance.....do you know of a pattern which has holes all the round
