I have used Inventor in combination with AutoCAD for commercial stone
facades, precast, PGRG, GFRC, etc. The end product was always AutoCAD. As an
example I modeled a classic portico for a 40,000 spft house in inventor then
saved as dwg. Inventor was the fastest way to draw and great for
presentations to the client but I find Inventor is to cumbersome when
compiling and annotating Architectural drawing sets (including shop
drawings). Also classical stuff is spline intensive which taxes Inventor. I
would not use Inventor for flat stone work. I can create joint layouts and
piece tickets much much faster in AutoCAD.
Al Jolley
ACJ Enterprises, Inc.
"Darren J. Young" wrote in message
news:MPG.1847219d6686fcb798982c@discussion.autodesk.com...
> I'm curious if anyone here uses Inventor for things that cross over into
> the Architectural fields, perhaps like structural steel, precast
> concrete, arcitechtural stone, etc.
> I've got a number of clients the do architectural precast concrete or
> stone fabrication. While these products go on buildings and are designed
> based on architectural blueprints, the end drawings are more mechanical
> in nature, piece parts to fabricate stone or piece parts that forms are
> fabricated from to pour the stone.
> Aside from what's referd to as the shop drawing, which are usually
> elevations andor pland, sections of the product in the location thay's
> go on the building, the remaining drawings are all piece parts.
> I've been thinking of playing around in this area a little with Inventor
> to see how it works up. Modeling the pieces in 3d would be a snap,
> changes resulting form field conditions or design changes could easily
> be done.
> Even the shop drawings (plans/elevations) I'd imagine could be done like
> an assembly.
> Anyone else doing anything like this that want's to share their results?
> Darren J. Young
> dyoung@mcwi.com
> Autodesk Developer Network
> AUGI Inventor Product Chair
> Minnesota CADWorks, Inc.
> PO Box 1172
> Monticello, Minnesota 55362-1172
> (763) 295-4433
> http://www.mcwi.com
> ftp://ftp.mcwi.com
