I got this monster of a part and I have no idea on what to do with it. I did some work on it and you just suppress or remove it to see the file in its original state. I removed two hickups just by using delete face. And that was no problem. However you'll see a big circle kind of thing in the middle. I have no idea on what to do with that thing. I tried removing it with delete face but to no luck. I tried cutting it out but then I don't know how to fill the gap up again. I don't know. This seems way past my level of knowledge. So I figured I would ask you, the people in here with infitite knowledge.
Thanks a lot for any advice and help you can provide!
Solved by WHolzwarth. Go to Solution.
I would start over from scratch.
That "big circle kind of thing" will need to be a placed Punch feature.
If you want to get a flat pattern without the punch, perhaps this can help.
But some further work is needed with bend radii.
Walter
Walter Holzwarth
Now the cleaned-up part with flat pattern.
Walter Holzwarth
