I download a cylinder assembly from Bimba and directly inserted it into Inventor from their website. I can't seem to manipulate the files at all. Like their read only or something. Anyone have seen these yellow 'nuts' before?
Solved by jletcher. Go to Solution.
That looks like a Content Center icon, but that's not how CC items show up in browser. What happens when you expand one of them?
Standard CC item in browser:
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
@ccomito.rsi wrote:I can't seem to manipulate the files at all.
Atttach one of these files here.
Go to iProperties of one of the files.
What version of Inventor was it created in? (my guess v7)
When expanded it looks like the attached. I also attached a model file.
Some sort of Write-Protection within Inventor. It shows all the features but are un-editable, sweet!
You can't even access the iProperties, they really don't want you to mess with it.
Yeah but how. If there's a way to do it then there's a way to undo it. Either way I think it would be benificial to know all Inventors "how to's"....
You can access the iProperties with Windows Explorer and iPropWiz seems them also and edit them.
Would love to know how to lock files down like this! Must do more research.
iProperties says it was created with 2013 SP1, but I suspect this is the OP saved version. Would be good to get the original unmodified file.
Yes I have seen this many times. This is a part that was downloaded from a web site cannot tell you what site there are many out there.
The file was made with a program called Taylor Made. (Spelling may not be right).
It is a generator lets say like an ipart. If I am a manufacture of nuts you come to my web site and instead of me (manufacture) making 1000 files I make one you come to my web site and configure the nut you want pick cad format and it makes the part in native format. Kind of like McMaster-Carr or Parker fittings....
The file cannot be changed or at least not suppose to be able to. Because it is a controlled file from the site it was downloaded from.
Not many use this program anymore better ones came out..
I am surprised Autodesk did not post to let you know. Not sure if they made the software but it was demoed by them back in Inventor 4 days.. I know I demoed it for parker fittings..
Found the web site for the software if you want to check it out.. And yes my spelling was not right LOL...
I've seen a similar problem from another parts web site.
The solution there was to
1) Download the file again, making sure that if there are options for different drafting programs select the correct one
2) Then OPEN the file
3) use the SAVE AS and give it a DIFFERENT NAME, making sure that it is in your current project folder
4) Close the file
5) Re-open the NEW/RENAMED file
6) Check that you now have full access
