Sounds good, Bill.
Now, try a small section of thread and array it to see if you can get
something you can work with (a minute or 2 for creation)
QBZ
"Bill Henry" wrote in message
news:392F2A7AD5F15070E20E0BF98CFC9952@in.WebX.maYIadrTaRb...
> We have been using the "coil" command to do this. We build the
profile of
> the thread, and then revolve it with the coil command. we have done
bolts
> as small as about an 8-32 over 1/2 inch in length (takes about a
minute to
> finish), and the largest, which we've never let run to completion -
3/4 Dia
> Acme thread over about 24"
> The steps we use are as follows:
> 1- create a shaft
> 2- build the thread profile
> 3- Align the shaft and thread profile properly, and apply the coil
command
> 4- wait
> 5- finish or crash
> In running MD in the past, I used to "work around" this by creating
> "representational" threads, but I was hoping IV had enough horsepower
to
> give me the real thing.
> Thanks again,
> Bill
> "Quinn Zander" wrote in message
> news:514DC167B370B4B74ABB255F7221413A@in.WebX.maYIadrTaRb...
> > Did you try arraying a small "easy" pitch of thread?
> > QBZ
> > news:62B5A77394FB37DE858B7A11F5C017C5@in.WebX.maYIadrTaRb...
> > > Hello,
> > > We are working on a very precise assembly that we need to see
actual
> > thread
> > > pitches on shafts and mating holes.
> > > We have run into a problem with this. If we do 1-10 pitches of a
> > thead
> > > profile, IV is fine. We need to run about 400 pitches on a long
rod,
> > and we
> > > have not been able to accomplish this, or rather, we "end task"
thru
> > windows
> > > manager to stop IV from working. The longest we have let a
machine
> > crunch
> > > is 50 minutes.
> > > We have duplicated this on 2 different machines, a laptop and a
> > desktop,
> > > both equipped very similarly, and have had the same results, so we
> > don't
> > > feel it is a hardware glitch.
> > > Has anyone else run across a similar problem, or have a solution
for
> > this?
> > > By the way we are running IV8.
> > > Thanks,
> > > Bill
