Inventor Forum
Any iTweak Requests
5 REPLIES 5
142 Views, 5 Replies
Any iTweak Requests
Any requests for the next version of iTweak?
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
5 REPLIES 5
First thought....
Since it was brought up la little bit ago...what about the reflection image in
the reg? I was thinking of your solution (just change the xxx.bmp to car3.bmp
(first change car3.bmp to something else...) , but what about those that do both
patent and normal drawings? they would have to keep renaming files all the time.
Easier to just run iTweak and switch it there.
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
"Sean Dotson" wrote in message
news:3E9503E7D4B24856CDE43ED12716D158@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
Min Show Parts Frame rate and View Transistion time. I know these are both in Application Options, but 90% of users don't change
them and get frustrated with the performance.
I'll think of some more...
John Bilton
"Be careful what you wish for, it may just come true"
John,
Anything you can change in App Options is non hidden. I'd just be repeating
UIs...
Sean Dotson, PE
"John Bilton" wrote in message
news:23B86509B5875D22C1F010F38AC5E7A5@in.WebX.maYIadrTaRb...
> John Bilton
rllthomas
I can't say that I've ever used iTweak so I don't know what it really does but a common problem is people using drivers newer than the HW lib supports and then getting the wrong settings. Any thing you can do to make this simpler, even perhaps giving an option to copy over the settings from the most current recognized driver or allowing one to copy the settings from a specific card to current.
How should these be set for best performance?
