Inventor Forum
Another quirky thing about the Inventor Library Content
1 REPLY 1
97 Views, 1 Reply
Since I wasn't able to find a Flat Countersunk Head Undercut Machine Screw
in iPartLand. I turned to our good friend, the Inventor Part Library. I
found the type and size I needed, after sifting through an infinite list of
types (they really need a better way to divide them into manageable groups).
I decided to open up the part and measure it, to make sure it was what I
wanted. While using the Rotate tool, I noticed on the Context Menu, that
Done is greyed out. What's the idea behind that? As if things weren't
cumbersome enough already, now I have use the Esc key to get out of the
command? I also learned that the angle is 80 degrees, not 82. Is that
correct?
Mike
1 REPLY 1
Mike
I use 82, ... I can send you my version of iPart CS screw that I included both undercuts,
and 100º in with the normal ones if you are interested.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Mike Maenpaa" wrote in message
news:A730D40D5472D28A3FFBEEB785F2E5F4@in.WebX.maYIadrTaRb...
> in iPartLand.
