You cannot not affect relationships when you move files. You can
minimize the effect it will have on relationships. Be sure to use the
UNC (Universal Naming Convention) on all paths, \\servername\foldername,
instead of using "mapped" drive letters.
The method I have had the best success with is to set the multi-user
off, open the highest level assembly in DA. Select all the
sub-assemblies (I usually do 1 or 2 subs at a time) and parts (except
library parts), use the rename operation and just change the location
(this moves the files rather than copying). After complete, I copy the
highest assembly to the new location, DA will not rename/move the
highest level assembly, only the subs and parts.
Modify the project file and open the assembly and hopefully the number
of resolve issues are minimal.
Hal Gwin
Mechanical Designer
Xenogen
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4201 drivers
Dell UltraSharp 19" LCD
