Inventor Forum
Another flattening riddle
4 REPLIES 4
278 Views, 4 Replies
I am trying to model a hollow curved disk as we would build it; faces cut form 1/8" material and roll formed and a return of.0625 thickness spanning the two.  The three parts were devived from disk3.ipt.   The faces both flatten.  The return thinks it flattened but did not.  Each of the 3 parts has its sheet metal rules thicknes set to "thickness".  I have learned a bit searching for someone's simalar problem but not solved my own.  I am pretty sure that this will flatten without deformation.
Any insight would be appreciated.
Zak
Tags (1)
4 REPLIES 4
mrattray
Inventor can't unfold that.
Mike (not Matt) Rattray
Thanks for the quick response.
It seems that Inventor 2013 can not unfold this yet I find that very hard to believe.
Considering Dr Mather's comment regarding part2:
http://forums.autodesk.com/t5/Autodesk-Inventor/How-can-I-flatten-these/m-p/3465526/highlight/true#M...
..MIGHT be able to be flattenned;  clearly part2 has compound curves.  I would have thought it impossible to flatten without deformation.  My return seems to me as it would lay flat as anything.  I guess I'll try something different to prove or disprove that notion.
Thanks.
Yup.  You are right, Mike.  Thanks
Still trying to solve what, seems to me, ought to be a simple problem.
Attached is a new version of the return that would not flatten.  A sweep rather than a patch between two surfaces.
No deleted faces.  Sheet metal environment  Thickness matches SM rule...
I exported this to Rhino where it does flatten yet it still will not in Inv2013.
Any insight?
Thanks in advance...
