hello
im trying to make an template we can use as default template..
now when i make a section view or a detail view of a part, the annotation is placed above the section view..
I would like to have that underneath the view.
I know can drag it down there, but is there a way to have the annotation underneath the view when its created? would save me and the rest who is going to use the template a lot of time..
thank you.
Solved by harco. Go to Solution.
Try here for help
References
>Style and Standard Editor - Standard
>View Preferences tab
Sets the default position of the view label.
Above places the view label above the drawing view by default.
Below places the view label below the drawing view by default.
Toggle Label Visibility controls the default setting for visibility of the view label.
Procedures
>Set the style for drawing views and view annotations
Use the Style and Standard Editor to edit the defaults for drawing views and view annotations.
NoteChanges affect the current document only unless you choose Manage tab Styles and Standards panel Save.
>Edit the view style
1. On the ribbon, click Manage tab Styles and Standards panel Styles Editor.
