Inventor Forum
Annotate problem: leader with text
6 REPLIES 6
Jefkee
465 Views, 6 Replies
Is it possbile to spread text gathered from the part description on 2 lines? cause on 1 line is in this case to long.
Inventor 2013
6 REPLIES 6
jletcher
in reply to: Jefkee
Yes but you have to make it a symbol and use text box put a dimension on the text box to control the text wrap.
jletcher
in reply to: Jefkee
There is another way but I can't find my cheat sheet that tells me how. There is a character you can place in the description and then you don't need to make a symbol but I can't remember.. If I find it I'll post..
mpatchus
in reply to: Jefkee
Another option is to make use of the part's COMMENTS iproperty.
In the past, I have utilized this iproperty for part descriptions so I could "break up" a long single line of text.
Simply use the ENTER key to break the text up as desired.
It's a workaround, but it does the trick for those clients of mine with long-winded part descriptions.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
jason.dupree
in reply to: jletcher
Anyone ever remember that character that creates the line break?
Jason Dupree
Senior Consultant - ECAD, Inc.
peter.hamas.ads
in reply to: Jefkee
sorry, but this option is not supported in Inventor directly,
there is another way of doing this if you are still interested,
please see this thread for more details
kind regards, peter
Thanks, Peter.
Jason Dupree
