Inventor General Discussion
Distinguished Contributor
Jefkee
Message 1 of 4 (191 Views)
Annotate problem: leader with text
191 Views, 3 Replies
10-03-2012 04:48 AM
Is it possbile to spread text gathered from the part description on 2 lines? cause on 1 line is in this case to long.
Inventor 2013
*Pro
jletcher
Message 2 of 4 (179 Views)
Re: Annotate problem: leader with text
10-03-2012 05:04 AM in reply to: Jefkee
Yes but you have to make it a symbol and use text box put a dimension on the text box to control the text wrap.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
*Pro
jletcher
Message 3 of 4 (173 Views)
10-03-2012 05:24 AM in reply to: Jefkee
There is another way but I can't find my cheat sheet that tells me how. There is a character you can place in the description and then you don't need to make a symbol but I can't remember.. If I find it I'll post..
James Letcher
Valued Mentor
mpatchus
Message 4 of 4 (171 Views)
10-03-2012 05:30 AM in reply to: Jefkee
Another option is to make use of the part's COMMENTS iproperty.
In the past, I have utilized this iproperty for part descriptions so I could "break up" a long single line of text.
Simply use the ENTER key to break the text up as desired.
It's a workaround, but it does the trick for those clients of mine with long-winded part descriptions.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
