Inventor Forum
Annotate (ESKD) - Technical Requirements
5 REPLIES 5
karthur1
1876 Views, 5 Replies
By accident, I loaded the ESKD Support add-in. Now on the Annotate tab (its now Annotate(ESKD)), I have a Technical Requirements tools.  This seems pretty nice because it seems like a good way to add some standard notes that we use often.  Problem is, this is not English.
5 REPLIES 5
in reply to: karthur1
I believe this is for GOST standard only (Russian).
Yes, this is for the GOST standard but the function of the technical requirements tool would be beneficial to all Inventor users. This should be rolled into the product as a normal feature.
OstapTM
If you still need you can add your own requirements in english
aargear
Not only ESKD technical requirements tool should be rolled into the product as a normal feature.
All from ESKD Add-in can be rolled into the product as a normal feature.
Huib_ManageCAD
in reply to: aargear
See attached document to add to Technical Requirements to your Annotations toolbar.
See also video: https://youtu.be/LUE743rPnVA
Kind regards,
-Huib
