Looking at it now, hovering around the actual circle doesn't make the dot show up, but I
do seem to remember cases where I had to drag across the circle to before the dot would
show up.... maybe I am mixing something else up with this.
About all I can suggest is to zip it up and post it to customer files where someone will
most likely take a look and give some feedback as to what might be going wrong.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"tmalinski" wrote in message news:f173587.1@WebX.maYIadrTaRb...
> Thanks Kent, I can now rubber band the vertical dim OK, but I still can't re-attach the
dim to the center of the hole. It lets me drag it to the dot in the center, but when I
drop it in place the extension line jumps away as if it is trying to snap to another point
somewhere. Is ther a way to control the snap points manually?
