When importing V3.5 files it should add the suppressed constraint to each
sequence after suppression and then not add it after the constraint was
unsuppressed in 3.5. In the options dialog for V4 you can toggle options to
automatically carry forward driven constraints, suppressed constraints, and
modified occurrences.
Neil
"cbliss" wrote in message news:401e7676$1_3@newsprd01...
> I would also expect that between sequences, any constraints suppressed
> in the previous sequence would remain suppressed until I change it.
> (the way V3.5 works). The animation I was working on when writing the
> suppression chunk of V3.5 had about 50 sequences so having to set
> identical constraints for each sequence would have been a lot of work.
> I suppose an easy way out would be to export to CSV, replicate the
> suppression in Excel and import back to Animator.
> Neil Munro wrote:
> >OK, I'll have a look. It should return them all to their initial
condition.
> >Thanks,
> >Neil
> >"Aernoud" wrote in message
> >news:1529644.1075733458840.JavaMail.jive@jiveforum1.autodesk.com...
> >>Neil,
> >>Maybe some misunderstanding from my side, but..
> >>I have some constraints suppressed, before starting Animator.
> >>Then I start Animator.
> >>I suppress and activate the constraints in the way you describe.
> >>When I close Animator I expected the originally suppressed constraints
> >will be suppressed again (the starting situation).
> >>This is not happening, all used constraints become active.
> >>So not longer the situation from just before starting Animator.
> >>Aernoud
