style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Todd_G" <Sean,
href="mailto:canaldover@tusco.net">canaldover@tusco.net> wrote in
message
href="news:f12a447.1@WebX.maYIadrTaRb">news:f12a447.1@WebX.maYIadrTaRb...
Can't wait to try this one, but having trouble getting it loaded. I downloaded
the .zip file which included the .pdf and the installer and followed the
directions in the .pdf. No new icon so i went to the add-in manager and the
only thing there was one called "Animator" not "Animator.clAnimator" like the
manual said. Not sure if this is why it's not loading. The "Animator" add-in
won't load it. Any help would be appreciated, looks like a really cool
program!
"MattH" <Now
href="mailto:matt@pennine-group.co.uk">matt@pennine-group.co.uk> wrote
in message
href="news:f12a447.0@WebX.maYIadrTaRb">news:f12a447.0@WebX.maYIadrTaRb...
this is a GREAT! program. Thanks to Sean, Neil and Charles for something so
small and beautiful yet so powerfull (3DS Max takes up 650Mb of disk space,
Animator3 - 232Kb, speak softly and carry a big stick!) All we need now is to
get Autodesk / Inventor to let us drive constraints in assemblies AND sub
assemblies and will put most animation software companys out of business
Regards
Matt Hutchinson
"Todd_G" <Yep,
message
href="news:f12a447.5@WebX.maYIadrTaRb">news:f12a447.5@WebX.maYIadrTaRb...
had IV closed. Just typed regsvr32 animator.dll at the command prompt and I
get a message LoadLibrary("animator.dll")failed - The specified module could
not be found. Still shows the "Animator" add-in and every time i load it it
doesn't show the new icon and when i go back to the add-in manager it shows it
as unloaded.
"Todd_G" <That
message
href="news:f12a447.8@WebX.maYIadrTaRb">news:f12a447.8@WebX.maYIadrTaRb...
did it...wasn't in the right directory *smacking forehead* Thanks for the help
Sean.
"Sean Dotson" <sean at sdotson dot com> wrote in message
href="news:965843CE4234380C4D9146C38E702649@in.WebX.maYIadrTaRb">news:965843CE4234380C4D9146C38E7......
Hmm.. Did you have Inventor closed when you
installed it?
Close Inventor
Try going to the location of the install (if
you used the default it will be c:\program files\autodesk\macros) in a command
window and then type
then double click on animator.reg say yes
to the next dialogue.
Reopen Inventor. See if the add-in is
there. Check it to make sure it's loaded.
Hope that works...
Sean Dotson,
PE
http://www.sdotson.com
Check the
Inventor FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
"Todd_G" <Sean,
message
downloaded the .zip file which included the .pdf and the installer and
followed the directions in the .pdf. No new icon so i went to the add-in
manager and the only thing there was one called "Animator" not
"Animator.clAnimator" like the manual said. Not sure if this is why it's not
loading. The "Animator" add-in won't load it. Any help would be appreciated,
looks like a really cool program!
