Well it worked in the beta but doesn't in R7. Easy fix however..(Thanks
Charles..)
Go to IVCF and download the zip file under this same topic.
I will also have them posted on my site
http://www.sdotson.com/vba/anir7patch.zip
There are two reg files. Overwrite your current reg files.
Probably in the C:\Program Files\Autodesk\Macros directory.
Double click on the Animator.reg file.
That's it. The other reg file is the updated uninstall reg file.
It should still work fine in R6....
Sean Dotson, PE
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
