Don't record the animation in a presentation file. Record it in the
assembly. Put an angular constraint between the crank shaft and an origin
plane and then drive this constraint. In this dialogue there is an option
to record the motion to an AVI file.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"quattda" wrote in message
news:f163d9f.2@WebX.maYIadrTaRb...
> Sean,
> In the assembly file the constraints work fine... the cam shaft will
turn fine by hand and the pistons follow suit, but when I try and take it to
a presentation, only the cam shaft moves and the pistons don't follow.
