Inventor General Discussion
Distinguished Contributor
nrg_drink
Message 1 of 19 (1,159 Views)
Animating Positional representations in Studio
1159 Views, 18 Replies
08-03-2010 02:15 AM
I'm using 2011 pro.  When I try to animate a positional rep in inventor studio, it complains that I don't have excel installed. (see attached image) although I do have it installed.  I've put the hotfix on for excel, with no effect.  I've repaired inventor and repaired excel no fix though.
Does anyone have any ideas ?
nrg_drink
Message 2 of 19 (1,119 Views)
Re: Animating Positional representations in Studio
08-09-2010 03:39 AM in reply to: nrg_drink
I thought I would try and bump this up, I really need an answer, I hope someone can help
Employee
bill.bogan
Message 3 of 19 (1,110 Views)
08-09-2010 07:39 AM in reply to: nrg_drink
We should probably start with basic information.
Inventor version? Default install path or other?
Excel version?
Machine info?
Bill
Bill Bogan
Principal Content Developer
Design, Lifecycle, and Simulation
nrg_drink
Message 4 of 19 (1,091 Views)
08-10-2010 01:56 AM in reply to: nrg_drink
Sorry,
I'm using Inventor Pro 2011 (64 bit)
Windows 7
Excel 2007
Dell M6500 12gb Ram
There are other people in the office using exactly the same spec, and they have the same problems
nrg_drink
Message 5 of 19 (1,090 Views)
08-10-2010 01:57 AM in reply to: nrg_drink
and everything is installed to the default paths, both excel and inventor
Employee
bill.bogan
Message 6 of 19 (1,070 Views)
08-10-2010 08:28 AM in reply to: nrg_drink
Great. thanks! We'll see what we can discern at this point. I or another person will be back with more information as soon as I/we have it.
Bill Bogan
Employee
bill.bogan
Message 7 of 19 (1,040 Views)
08-11-2010 10:29 AM in reply to: bill.bogan
Try this post: http://forums.autodesk.com/t5/Autodesk-Inventor/linking-an-excel-file-using-inventor-2010-and-window...
Saving you time...
Re: linking an excel file using inventor 2010 and windows 7
05-06-2010 12:40 PM in reply to: pmoske
Is this a 64-bit system? These solutions are only for 64-bit Windows 7.
Did you try running the script again to remove the entries, then again
to add them? (Soren Skjoldborg tried that back in November and it helped.)
Microsoft acknowledged the problem is with the interaction between
Windows 7, its default entries for things like searching, and Office.
You can see that even things like WordPad exhibit the same bad behavior
by trying to link a spreadsheet to a document in WordPad (it embeds it
instead of linking to it). I don't know what the status is for a fix
from them.
One other approach you might want to try is to rename the key yourself
(I recommend renaming so you can restore it if things don't work). Use
Registry Editor and find
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{00020820-0000-0000-C000-000000000046}.
Rename that key to something else, perhaps by prepending "zzz"
("zzz{00020820-..."). By doing that, it forces Windows to use the 32-bit
entries, and that should work.
You can confirm this by trying to link a spreadsheet into a WordPad
document---when things are broken, it will only embed (you'll see a
spreadsheet icon), but when things are working, it will be linked
(you'll see the spreadsheet entries).
Bill Bogan
nrg_drink
Message 8 of 19 (1,001 Views)
08-16-2010 03:11 AM in reply to: bill.bogan
It's not that, I can quite happily link excel tables into IParts etc (although the hotfix was required) It's just animating the postional representations that cause a problem
Valued Contributor
pdauphin
Message 9 of 19 (968 Views)
09-24-2010 05:52 AM in reply to: nrg_drink
Any solution came up for this problem? I have the same problem here...
Thanks.
Employee
bill.bogan
Message 10 of 19 (949 Views)
09-24-2010 08:50 AM in reply to: nrg_drink
Let me see if I understand this correctly...
  1. You bring values from excel into Inventor. Do you assign them to/as parameters?
  2. You then use the parameters/values to modify PRs. The PRs work in the assembly environment - no problem?
  3. In Inventor Studio, you use the Animate Positional Representations (PR) command to animate between specfied PRs
Does that accurately describe the process - albeit more steps may actually be required?
And, if that is the process, are you having problems with phase 3?
Bill Bogan
