Inventor Forum
Animate two gears in Studio -2011
1 REPLY 1
karthur1
249 Views, 1 Reply
I have two gears.  In the assembly I have them setup to mesh correctly.  I can drive the constraint on the pinion and the gear will follow it (some what).  I wanted a better video of it, so I went into Studio.  Now when I drive the constaint like before on the pinion, the gear goes crazy.
http://screencast.com/t/lTaaPaup6O
There is a rotational translation constraint set between the pair (= to inverse of gear ratio) that works in the iam, but it is like Studion ignores it.  How can I animate this to show the gear mesh?
1 REPLY 1
Xun.Zhang
in reply to: karthur1
It's a problem indeed, I have to log a defect on our defect system, thank you for the feedback.
Xun
