Inventor Forum
Animate converging geometry
4 REPLIES 4
nsulli15
267 Views, 4 Replies
This may not be the right forum for this question, but maybe someone can guide me in the right direction.
I would like to be able to show an animation of a flat plate of material converging into a half hollow sphere (like a bowl). Its easy to model the beginning and end stae, but I do not know how to show it transitioning from one to the other.
Does anyone have any ideas on how to do this?  I need it for a presentation to convey a design concept.
4 REPLIES 4
CCarreiras
in reply to: nsulli15
Hi!
It's possible in the inventor studio inviroment, you have to vary one parameter and animate this variation.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
JDMather
Make the "flat" plate as a very large radius (approaching flat) and arc length.
Give the radius a parameter name and then Animate Parameter in Inventor Studio as suggested.
rdyson
in reply to: CCarreiras
PDSU 2016
JDMather
in reply to: rdyson
Nice example - keep this one around for every time this question comes up.
It would be really cool if you could set it to fade to transparency and have a gold fish (or Nemo) make a loop around the bowl.  Whatever happened to Friday pics?
