Inventor Forum
Angular Constraint Bug
13 REPLIES 13
Message 1 of 14
161 Views, 13 Replies
Just had to bring this to the front once more. I went home and tried a
direction change on an angular constraint in 5.3 and I can flip it all day
long just by changing the arrow direction....this absolutely does not work
in R7! (don't know about R6 though)
If this is not a bug then the change angular constraint direction function
must have been eliminated in R7 and they forgot to remove the buttons. As
far as I am concerned this is not a feature I can do without. If AutoDesk is
listening, is this a known bug ? is it being addressed?
In all fairness this is the first "real bug" I have seen in R7 and you guys
did a real good job over all but can I /we please have this feature back?
13 REPLIES 13
Message 2 of 14
Like the Pink Elephant thread these three messages discussing bugs have been squashed.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Larry Caldwell" wrote in message
news:B01F9CCD9AEF43B24F36C8019B080A27@in.WebX.maYIadrTaRb...
> Bug-Busters Inc.
Message 3 of 14
Kent, that one was so bad that it was good.
But seriously, am I the only one that needs this feature to work? I figured
there would be people coming out of the woodwork (no pun intended) to
complain about this.
"Kent Keller" wrote in message
news:D369D5C01E8B91B404418B5CAE84C9FE@in.WebX.maYIadrTaRb...
been squashed.
> Kent
> Assistant Moderator
> > Bug-Busters Inc.
Message 4 of 14
Albert,
See iCF. Try to edit the angle and flip one of the arrows. It flips for
me...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Albert Allen" wrote in message
news:08FB31AF2A41E26B640174255FDCE95B@in.WebX.maYIadrTaRb...
figured
> been squashed.
> > Kent
> > Assistant Moderator
> > > Bug-Busters Inc.
Message 5 of 14
Hey Sean, try it on two round shafts with the cl's aligned then change the
angle direction (use something that has a flange on the end so you can tell
whether it flips)...betcha it doesn't work. now try that same thing in R5.3
(it works) and maybe in R6 too but don't know for sure.
"Sean Dotson" wrote in message
news:669DFA101BFF646A2E0B4DF75EAC723F@in.WebX.maYIadrTaRb...
> Albert,
> me...
> Sean Dotson, PE
> figured
have
> > been squashed.
> > > Kent
> > > Assistant Moderator
> > > > Bug-Busters Inc.
Message 6 of 14
I have found that if you place your angle constraint between two round
shafts (forgot to mention it's only on round shafts) and if you change the
direction before you actually pick the 2nd part then you (sometimes) are
able to get one direction change before it doesn't work anymore. Sorry about
the anality but I need this to work.
news:CFE03A44EB6C3A13E483F719CEC06A19@in.WebX.maYIadrTaRb...
is
guys
Message 7 of 14
Albert:
Just out of curiosity, Have you tried applying the constraints between
the construction axes?
For example, if the round shafts are symmetrical about the X axis in
each case, does your problem still exist?
Richard
> is
> guys
Message 8 of 14
Yes, if the axis' of the shafts are angularly constrained at 0° I am not
able to flip the direction, the arrow shows the reverse direction but the
parts do not reverse their alignment. This problem exists on all three of
our machines which are all different so this is not a "hardware" problem.
I guess no one else uses an angular constraint between two shaft axis' where
they need to flip the direction.
"Richard Hinterhoeller" wrote in message
news:3EC29649.2040302@hfx.eastlink.ca...
> Albert:
> Richard
the
about
day
work
function
As
AutoDesk
> > is
> > guys
back?
Message 9 of 14
Or how about between two origin planes of the rods. I haven't tried it but
I suspect if these is a problem it's due to the fact that the axes can spin
and flip. The planes should not allow this.
Sean Dotson, PE
> Albert:
> Richard
the
about
day
work
function
As
AutoDesk
> > is
> > guys
back?
Message 10 of 14
I have not tried it either Sean but I am sure that it would work.
The bottom line is I have used the angular constraint this way in the other
versions with no problems many, many times and have lots of assy's with
things constrained like this, so now all of the sudden I need to start
aligning my shaft axis' to the origin planes to get them to line up at the
direction I want? If this way of aligning does not work this way any more
does this mean that all my assy's that have constraints like these in will
be unstable?
I have already read some posts where folks have had there angular
constraints flip on them, I wonder if this could be the cause?
news:31F3ACB6BEAC242D26417CE52C693FB0@in.WebX.maYIadrTaRb...
but
spin
Message 11 of 14
Albert,
I experience this too except I have an ABS sensor (shaft) and a mounting
block (hole) that have mate constraints on thier centerlines. The sensor
has a cord that comes out perpendicular to the body, so I need to orient it
it the proper direction. I do this by placing a 0° angular constraint on a
face of the sensor and on the XY plane of the block. When I flip the
direction, the arrow flips but not the sensor. I have to delete or supress
the constraint, orient the sensor somewhat close to how I want it, and then
add or unsupress the constraint. Anyway, it's not just 2 shafts.
Apparently it happens with other geometries too.
Mike
news:8318999177B7AFA7980EFCAD2BC5C77F@in.WebX.maYIadrTaRb...
about
Message 12 of 14
Mike, at least I am not imagining this but I guess there are not enough
people who use this constraint to warrant a fix or even acknowledgement of a
problem by AutoDesk so I guess I will stop beating the dead horse...(for now
anyway)
"mpower" wrote in message
news:0B4698F13C79E27E9F5897DA8C1A5F1C@in.WebX.maYIadrTaRb...
> Albert,
it
a
supress
then
> Mike
Message 13 of 14
I use it Albert, but probably not as often as you. It would be nice to get
it working, I agree. It's an ease-of-use issue I would guess.
BTW ... are you sure that horse you've flogging is really dead?
~Larry
news:27A2C823D558A00033D65993F85DE3B1@in.WebX.maYIadrTaRb...
a
now
> anyway)
> > Albert,
sensor
> it
on
> a
> supress
> then
> > Mike
Message 14 of 14
He had better be because I have had horse steaks every day this week!
Take that all you "neigh" sayers
> ~Larry
