Albert,
I experience this too except I have an ABS sensor (shaft) and a mounting
block (hole) that have mate constraints on thier centerlines. The sensor
has a cord that comes out perpendicular to the body, so I need to orient it
it the proper direction. I do this by placing a 0° angular constraint on a
face of the sensor and on the XY plane of the block. When I flip the
direction, the arrow flips but not the sensor. I have to delete or supress
the constraint, orient the sensor somewhat close to how I want it, and then
add or unsupress the constraint. Anyway, it's not just 2 shafts.
Apparently it happens with other geometries too.
Mike
"Albert Allen"
wrote in message
news:8318999177B7AFA7980EFCAD2BC5C77F@in.WebX.maYIadrTaRb...
> I have found that if you place your angle constraint between two round
> shafts (forgot to mention it's only on round shafts) and if you change the
> direction before you actually pick the 2nd part then you (sometimes) are
> able to get one direction change before it doesn't work anymore. Sorry
about
> the anality but I need this to work.
