It is highly likely that I am going about this all wrong, but I have two components that work together great with contact solver. Cam/ramp moves an Arm with no problem. However, without gravity or a spring, the Arm stays at the extreme that Cam/ramp pushed it to. So I thought trying to put angle limits on Arm would help. Limits match the range of motion produced by Cam/ramp pusing it. Great. Now if I put an use a resting position on the Arm, the arm always springs back. Perfect, I feel like I'm a genius. However, trying to use contact solver AND the angle resting postion things go wrong. The angle resting position is STRONGER than the cotact solver and pulls the Arm through the Cam/ramp.
Before someone suggests a Transitional constraint, I have not been able to make that work and I think that my geometry prohibits it.
I also feel like attaching the file would help but my legal department wouldn't like that and redrawing all this to eliminate everything "sensitive" to be kosher isn't very appealing right now.
Thanks in advance!
Attach your assembly here.
You can enter min/max and resting position in Assembly Constraints.
There are other more sophisticated techniques involving Dynamic Simulation as well, but first, let's see what you have.
While someone takes a look at this - I recommend that you install the latest Service Pack and Update for your version of Inventor.
