Inventor Forum
Analyze Faces
3 REPLIES 3
1028 Views, 3 Replies
Analyze Faces
I know how to use the Analyze Faces and Draft tools, but once they have been used, how do you shut them OFF? The only way I have found is to "undo". What am I missing? The helpfile doesn't even mention turning the tool off.
3 REPLIES 3
There is a way to turn it OFF. Please look for a "Analyze Faces" switch as
shown in the image in the IPT file.
shekar
wrote in message news:4813474@discussion.autodesk.com...
>tool off.
> Thanks,
Thank you Shekar..the switch was not on my toolbar, so I put it there now. It also works to shut off Draft Analysis. Too bad there is not a button for Draft. The Zebra display is immediate from the toolbar button, but you have to go into the tools menu to get the Draft choice.
If no analysis is defined using Tools, Analyze Faces when you click on this
button we show the Primary Zebra analysis. Clicking it one more time turns
it analysis OFF.
If analysis is defined using Tools, Analyze Faces, depending on which one is
the active analysis style, clicking on the button turns the active analysis
style ON. Clicking it one more time turns it OFF.
The active analysis style is the one in the Tools, Analyze Faces dialog box
(Primary Zebra, Primary Draft, Draft1, etc) that is highlighted. Thanks.
shekar
wrote in message news:4813931@discussion.autodesk.com...
