Hi guys,
I have remodeled a part I was wokring on previosly, but now an edge doesn't want to fillet, as it was on the old model ( in the top right corner )... maybe someone could suggest, what the probmel?
Thanks!
Solved by JDMather. Go to Solution.
I didn't open the files to compare - but that fillet looks to be significantly larger?|
My firts thoguht is to use a Face Fillet rather than Edge Fillet.
I was able to add R12 fillet but it doesn't look like your image?
Also - I noticed that Sketch1 isn't constrained.
You might want to read this document and then start over - it looks like you are doing too much work.
http://home.pct.edu/~jmather/skillsusa%20university.pdf
or
Check out free Inventor Fusion http://labs.autodesk.com
