Inventor Forum
An assembly that went from terrible to great!
4 REPLIES 4
albert
283 Views, 4 Replies
I have an IAM of a fairly large assembly that it was getting so slow to add a constraint I was just about to give up (30 seconds to 1 minute per constraint).
In a last ditch effort I grounded all constrained component's in their proper position and then suppressed all constraints...presto, I can now add new parts and constrain them effortlessly! I do however after constraining new parts just ground them and suppress the constraints.
For a test I un-suppressed all the constraints and all is good as long as I don't try and add new parts or constraints.
Is this normal?
4 REPLIES 4
JDMather
in reply to: albert
http://forums.autodesk.com/t5/inventor-general-discussion/inventor-2013-assy-getting-very-slow/td-p/...
johnsonshiue
in reply to: albert
Hi! What release of Inventor are you using? Without seeing the actual case, it is a bit hard to tell where the exact problem is. I assume there is already a grounded part in the assembly? If no, please ground at least one component. Based on your description, adding one constraint takes 30~60 minutes does not sound right to me. If the assembly is in fully-solved state before you add the new constraint, the new constraint should be solved very quickly. Certainly, it depends on if there are a lot of adaptive features or assembly features (they can interrupt the regular constraint solve process and it would take a bit longer to solve). Another thing to try is to activate Master Design View. Does it constrain faster when Master DV is active?
I can set up a secure account for you to upload the entire assembly. I would like to take a look and understand the behavior better. Please send me an email so I can follow up with you separately (johnson.shiue@autodesk.com).
Many thanks!
Software Test Engineer
albert
in reply to: johnsonshiue
No adaptive parts, no DV's....I did suspect a part and it's pattern at one time but after suppressing the part/pattern there was no difference. I find that large assemblies sometimes will have constraint issues so grounding all componenets and suppressing constraints might not be bad for assemblies that rarely have changes anyway.
johnsonshiue
in reply to: albert
Hi! If possible, I would like to take a look at the assembly. I can set up a secure server for you to upload. Please send me an email directly (johnson.shiue@autodesk.com).
Many thanks!
