Hey guys,
I want to be able to influence the value of a part parameter using ilogic in a drawing file.
Currently I have a Input Box list set up in a drawing file with numberous options for the user to select. (Via a MultiValue Parameter)
How can I link the selection of the Input Box list to alter the value of a parameter in a related part file?
E.g - Input User Box - Select Beam size: 1/2/3
User selects "2"
Part file parameters update to suit User selection.
Sandy,
P.s I have tried using the ParameterMakePath fuction but without success,
Cheers,
Solved by mrattray. Go to Solution.
Thanks Mike,,
The other trouble I am having is updating the relative parts and assembly files which this ilogic will affect. I have tried to use my events trigger & set to any paramater change but I cant get it to work. I have to open the parts and click update in order for the drawing to update.
Any help on this issue would be much appreciated,
Sandy
Try adding this anywhere in your rule:
iLogicVb.UpdateWhenDone=True
No Luck. I still open up my child part & it still wants it to update. The parent assembly is the same.
Try adding a rule to your "child parts" as follows:
localTrigger = YourParameter InventorVb.DocumentUpdate()
Replace "YourParameter" with the name of whatever parameter your trying to change from the drawing file.
Adding that to my child part does the job. Thanks. I also added it to the part above it (which my child part is derived into) and the assembly file above that. Neither of which are updating still. I derived in the paramater & reference in the code of each of the 2 files above my child part but they still wont update.
If I run the Rules the parts update but I dont think I can run the rules from event triggers base on a lower parts paramater change.
Sandy
Mike, this is what I was looking for!
@mrattray wrote:Try adding a rule to your "child parts" as follows:
I'm wondering though: Is there a way to trigger the document update on any parameter in stead of having to name specific parameters? Or perhaps a rule/form combination that allows me to update using an update button in the drawing?
As you can Imagine I'd like to make my templates so that I never have to worry about this again.
