In SW I was able to create assemblies that had components with limited motion and then set them as "Fllexable" and allow them to move in larger assemblies. How do I do this in Inventor? I have a trailer with both the front and rear axles able to pivot. These axle sub-assemblies are both able to pivot as top level assemblies but when they are assembled in the trailer assembly the only way I have found to allow movement is to make one axle active and move it then activate the other nad move it. This doesn't work well if there are several interdependant subassemblies that should move together. I am in Inventor 2012.
Thank you
Jim
Solved by JDMather. Go to Solution.
@JimSteinmeyer wrote:In SW I was able to create assemblies that had components with limited motion and then set them as "Fllexable" and allow them to move in larger assemblies. How do I do this in Inventor?
Exactly the same way you do it in SWx.
Right click on the sub and set Flexible (this assumes you haven't used Adaptivity).
The CADWhisperer YouTube Channel
Thank you JD,
I guess I hadan't found that yet.
