Hello all,
I have two seperate parts that I have laid out on a drawing. I wish to align these parts.... Is this possible? What is the best way?
tks! 🙂
Solved by Cadmanto. Go to Solution.
RC on the view you want aligned and select "Align" and follow the prompts.
You will have options to align the view in position, horizontally and vertically to what ever view you want
it aligned to.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thank you! I had even RC'd before and just didnt see it...when I clicked the 'Alignment' I noticed it also highlighed on the ribbon bar and changed from 'Break Alignment' to the one I selected.
Appreciate it! 🙂
