Inventor Forum
Aligning parts
4 REPLIES 4
772 Views, 4 Replies
Aligning parts
Here's another one which I am sure is an easy task for most but has me frustrated....
I have added 4 gussets to my assembly of two parts.  All I am trying to do is to align the gussets 90 degrees apart from each other and starting at 45 degrees on each side of the tapped hole.  I have one almost positioned except it can still move along the surface.  How should I tackle this?
4 REPLIES 4
cean_au
when u finish the first, array out the rest.
and if you creat one part insetad of an assembly, the gusset can be rib feature, much eash to creat.
in reply to: cean_au
The problem with this issue is not how to do the next 3 but how to secure the one where it needs to go and/or is there a better way than the way I was placing that gusset to be more efficient at it.
Jonka45
You are virtually there, Use a mate constraint from the plane you created to the plane through the center of the gusset then pattern the gusset to get 4 instances at 90 degrees.
Inventor 2022 Proffesional
Alienware Aurora R8
Windows 10 pro
Inside Leg 35 inch
JDMather
Mate the workplane to the central axis.
