Is there any way to align leaders in a drawing file? I can't even seem to get a "tracking" line so I can manually align them.
Solved by Cadmanto. Go to Solution.
Tommy,
Is this what you are looking for? If you hold down the ctrl key, select your dimensions and RC you will see this.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Sorry, I wasn't specific.... I'm referring to Leader text, not dimension leaders.
No problem.
If you are talking about something like this, I am not aware of anything.
That would be it. I have 10 leader callouts and I want them aligned vertically. I can eyeball it but it seems like there should be an auto align similar to the dimension align option.
I posted an idea in the idea station relating to this. Check out the link below.
http://forums.autodesk.com/t5/Inventor-IdeaStation/Align-Leader-Text/idi-p/4298872
I appreciate that. I'm new to Inventor and I didn't know about idea station. Thanks for your input.
Hey Tommy,
I have the same issue. I did find a workaround to place the text horizontal. Hold control while creating a leader line. you can see that the line snaps horizontal. Hope this helps you out!
