Duncan,
What you're seeing is the dimension centering behavior that was added in R9.
As Rory mentioned, this centering behavior can be temporarily disabled by
holding down the Ctrl key, but you can also turn it off permanently be
unchecking the "XXX" control on the Drawings tab of Application Options.
The centering functionality is covered under What's New in R9 help under
Drawing Annotation improvements.
Cheers,
Andrew Faix
Product Designer - Inventor Drawing Manager
autodesk
"Duncan Anderson" wrote in
message news:411b61f7_3@newsprd01...
> Rory,
> Thanks.
> When did it that change and why ? And why wasn't it documented ?
> I'm going to re-read the subscription licence, see if it mentions Cavia
> Porcellus in the small print.
> I've heard of the Waterfall method of product development, but I'm sure
Adesk
> use the Princess Diana Memorial Fountain method - one step forward, two
back and
> then slip over :-(
> Duncan
> "Humour ... is one man shouting gibberish in the face of authority, and
proving
> by fabricated insanity that nothing could be as mad as what passes for
ordinary
> living."
> (Terence 'Spike' Milligan K.B.E., 1918-2002)
> "Rory" wrote in message
> news:411b58ce_2@newsprd01...
> > Duncan,
> > Hold down CTRL when placing the dimension and you can put the text
wherever
> > you want.
> > Regards
> > Rory
in
> > message news:411b5274_1@newsprd01...
> > > When you place a dimension and the text is too large to fit between it
has
> > > previously been possible to move the cursor either left/right or
up/down
> > to
> > > place the text outside the dimension and in the most convenient place.
> > > Currently it can only be placed either left or down of the dimension
and
> > you
> > > have to go back and edit it ! ! !
> > > I've already put in a bug-report, but though others would want to be
> > aware,
> > > hopefully somebody's got a work-around.
> > > Duncan
and
> > proving
> > ordinary
> > > living."
